Author Topic: ShapeScript: users can't change set color  (Read 6851 times)
bITs.EA
« on: January 23, 2017, 07:41:57 pm »
Hi
In my shapescript, I want to define a default fill color (eg. setFillColor(255,255,255) ) for my shapes, but my users need to be able to change the colors when they design a model. Is there a way to achieve this with shapescript? Or do I need to use the "default" colors and forget about my default fill color?
S
Uffe
Re: ShapeScript: users can't change set color
« Reply #1 on: January 23, 2017, 10:30:04 pm »
Try color queries.
/Uffe
bITs.EA
« Reply #2 on: January 23, 2017, 11:09:00 pm »
In case of color queries, you depend completely on the users choice and you can't set a default (or can you?).
What I want is :
- Setting a default myself
- Give the user the opportunity to change that color
bITs.EA
« Reply #3 on: January 24, 2017, 12:28:10 am »
I found the answer myself:
1) Don't set the color in the ShapeScript
2) Select the stereotype and press "F4" to show the Default Appearance dialog
3) Set the desired default appearance.
--> Now the elements are shown in the default appearance, but the user can change this appearance
« Reply #4 on: January 24, 2017, 08:18:09 am »
What you should do is define the colour(s) associated with your stereotype when you create your profile.
Users can then override your default colours locally (for a single diagram) or as default like the way you are currently doing it (for a single element).
