Author Topic: Document generation not working with alternative images with transparencies v13  (Read 4603 times)
GrahamH
I've raised a bug for this, but I though it was worth checking to see if any body else is having the same issue or if it's my set-up.
If I have an element with an alternative image set that has a transparency, the transparency does not seem to work and shows as black in 13 when I tray and generate a document with the image.  Just checked in 12.1 and it works correctly
If you do 'CTRL + T', the image/file generated in both 12.1 and 13 seem ok though.
