Author Topic: Searching for special characters in element name  (Read 5151 times)
mrblack12
« on: January 23, 2017, 11:44:30 pm »
I'm trying to construct a search query that searches for elements with a special character - like &,*,+,), etc. - in the name. I'm doing this using a wildcard search but the only character for which it doesn't work is the wilcard character itself: '*'. Using just an asterisk as search term results in the entire repository, duh!
I'm thinking there might be a way by using an escape character like a forward or backward slash but that doesn't seem to do the trick either. Any suggestions on this?
Thanx,
Rick
« Last Edit: February 01, 2017, 01:47:02 am by qwerty »
mrblack12
Re: Searching for special characters in element name
« Reply #2 on: February 01, 2017, 01:44:26 am »
Found it! Turns out you have to use the square brackets: so using
  • as search term will find all elements with an asterisk in them, instead of returning everything....
« Reply #3 on: February 01, 2017, 01:47:51 am »
Ooops. Just saw that YABB swallowed it. I updated the post :-[
