Author Topic: Scripting : Call Behaviour Action  (Read 5331 times)
Filip Briké
« on: January 26, 2017, 12:38:58 am »
I want to script an action on an activity diagram that has call behaviour linked to an activity.
set newelement = package.Elements.AddNew("","Action")
newelement.ClassifierID = originalAction.ClassfierID
newelement.Update()
dim newactionondiagram as EA.DiagramObject
set newactionondiagram = currentdiagram.DiagramObjects.AddNew("","")
'l=200;r=300;t=100;b=20;
newactionondiagram.ElementID = newelement.ElementID
newactionondiagram.Update
However this does not make it a CallBehaviour (properties/general/advanced => kind : CallBehaviour) even when teh ClassifierID is set.
Which properties should i put?
Re: Scripting : Call Behaviour Action
« Reply #1 on: January 26, 2017, 01:02:46 am »
Hi
You mean , you're asking how to create a callBehaviour activity..?
If so you need to set there tagged values.
EA.TaggedValue activityType = activityElement.TaggedValuesEx.GetByName("activityType");
                    activityType.Value = "Sub-Process";
                    activityType.Update();
                    EA.TaggedValue calledActivityRef = activityElement.TaggedValuesEx.GetByName("calledActivityRef");
                    calledActivityRef.Value = addedElement.ElementGUID;
                    calledActivityRef.Update();
                    EA.TaggedValue isACalledActivity = activityElement.TaggedValuesEx.GetByName("isACalledActivity");
                    isACalledActivity.Value = "true";
                    isACalledActivity.Update();
and for diagram navigation you need to use SetComposite  proprty from element class like below
activityElement.SetCompositeDiagram(diag.DiagramGUID);
Setting all the above mentiond property will make a element as a callProcessref and composite diagram for it.
« Last Edit: January 26, 2017, 01:09:25 am by Arshad »
« Reply #2 on: January 26, 2017, 04:22:59 am »
Hi
What you are describing is valid for BPMN, but not for a UML CallBehaviorAction.
I'm sure you need to set the Classifier to the ID of the Activity you are calling.
The fact that it is a CallBehavior type is stored in t_xref as
@PROP=@NAME=kind@ENDNAME;@TYPE=ActionKind@ENDTYPE;@VALU=CallBehavior@ENDVALU;@PRMT=@ENDPRMT;@ENDPROP;Not sure how to set that using the API though. Probably using EA.Element.CustomProperties
