Author Topic: Document Generation- Stylesheet doesnt work after changing the format  (Read 8939 times)
Capmur
Hello everyone,
I am trying to generate a document and I do have a problem:
Some of my colleagues used the proper format e.g. heading1 but after they choose the format they changed some small things like the color.
When I generate the document and choose the stylesheet everything is fine except of some heading 1 formated text.
 The result is, that the for example the numbering of the document is blue and the text is black (attached you find an example where we generated a second heading to proof our thesis)
In the picture the first heading was edited after defining the format ( in that case heading2)
and in the second one after defining the format we didnt touch anything at all.
So do you have any idea to correct this without changing all the formats again?
I hope you guys can help me
Greetings,
Capmur
« Last Edit: January 26, 2017, 02:34:02 am by Capmur »
Re: Document Generation- Stylesheet doesnt work after changing the format
« Reply #1 on: January 26, 2017, 03:19:15 pm »
Hi Campur,
I've seen the same problem, and it can be a difficult one to solve.
I often had to copy/paste sections from other templates (with the right formatting) to get this working properly.
Capmur
« Reply #2 on: January 30, 2017, 02:40:18 am »
I couldnt solve it. Finally we had to copy paste the related headings with the proper format.
We made a table of contents to see which headings had to change.
Anyway, I have another question:
The size of the numbers and the heading are different. How can I adjust the size of the numbers?
« Reply #3 on: January 30, 2017, 07:18:30 pm »
That I haven't seen before. I'm not sure if you can control the size of the numbers separately from the rest of the heading.
Nabil
    • View My LinkedIn Profile Here
« Reply #4 on: January 31, 2017, 09:23:32 pm »
If no luck, to fix better try to create new style template.
BR,
Nabil
Nabil
MatthiasVDE
« Reply #5 on: March 13, 2020, 09:14:00 pm »
Bump...
I also use a stylesheet and have also a little problem.
The fonts and sizes works fine, but he doesn't use the colors that I specified in the stylesheet.
Is this normal?
« Reply #6 on: March 13, 2020, 09:36:22 pm »
Yeah, colors are difficult sometimes.
I try to make sure the color in my template actually matches the color in the stylesheet.
