Author Topic: How do I specify a set of values for run states?  (Read 6805 times)
AndyJ
  • It's only a model
« on: January 31, 2017, 11:14:22 am »
Hi people,
I'm pulling my hair out, because I believe that I've achieved this before (maybe I was dreaming).
I'm trying to create something as a base class (object, entity, whatever) which has a set of attributes, many of which are to be defined as enumerated lists.
The end product is something that I can drag onto diagrams, as an instance, and then set the "run state" for each of the attributes, by selecting values from the enumerated list associated with that attribute.
These things represent "nodes" in "workflows" so my final intention is to link these instances to each other with sequence flows.
Andy
AndyJ
  • It's only a model
Re: How do I specify a set of values for run states?
« Reply #1 on: January 31, 2017, 11:52:58 am »
I think I'm going to have to do this with tagged values :(
along these lines:
Detail:
Type=Enum;
Values=A,B,C,D;
Default=B;
« Reply #2 on: January 31, 2017, 07:56:59 pm »
I would expect the "set runstate" feature to be at least this intelligent to propose the enumeration values if you choose an attribute that has an enumeration as type, but apparently it's just a free text field. :-\
AndyJ
  • It's only a model
« Reply #3 on: February 03, 2017, 09:01:16 am »
Set run state is a useful feature, so I'm disappointed that I wasn't able to achieve this with that feature.
