Author Topic: MDG Office Add-in v1.0.7.0 Exception  (Read 6962 times)
JonTP
« on: February 02, 2017, 03:00:13 am »
Afternoon everyone
On loading Powerpoint 2016 (Windows 10) with the MDG Office add-in installed I get an exception thrown were the logged text is:
"Could not load file or assembly 'EAWordImporter, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format. "
There is plenty more in the dump but the following is logged
"\Office16\POWERPNT.EXE
--- A detailed error log follows.
=== Pre-bind state information ===
LOG: DisplayName = EAWordImporter, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null
 (Fully-specified)
LOG: Appbase = file:///C:/Program Files (x86)/Sparx Systems/MDG Integration for Microsoft Office/
LOG: Initial PrivatePath = NULL
Calling assembly : EAWIPpt, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null.
LOG: This bind starts in default load context.
LOG: No application configuration file found.
LOG: Using host configuration file:
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.
LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
LOG: Attempting download of new URL file:///C:/Program Files (x86)/Sparx Systems/MDG Integration for Microsoft Office/EAWordImporter.DLL.
ERR: Failed to complete setup of assembly (hr = 0x8007000b). Probing terminated."
Also the EA Ribbon is not shown unless add-in (from the options add-in page) is deselected and then selected. It is then shown but none of the icons function.
Anybody any clues?
JP
JonTP
Re: MDG Office Add-in v1.0.7.0 Exception
« Reply #1 on: February 03, 2017, 03:47:28 am »
SOLVED: Uninstalled MDG plugin. Reinstalled. Problem went away - no exception flagged.
roman104
  • Right Information - In Right Time - for Right Role
« Reply #2 on: April 27, 2018, 07:27:11 pm »
I am the same problem.
But re-installation of MDG did not help.
OS. Microsoft Windows [Version 10.0.14393], 64 bits.
MDG : mdgoffice64.msi
MS Office 2016
Screenshot with Error message is here This is Error message screenshot
The problem is with all MS Office application, Word, Excel, Powerpoint, Visio.
Any suggestions?
Thank You in advance
Roman
« Reply #3 on: April 27, 2018, 10:02:37 pm »
Hi Roman
What is the version of office you have installed ?
  • For 32bit of office applications you need to installe mdgoffice32.msi and
  • For 64bit of office applications you need to installe mdgoffice64.msi
HTH]
« Last Edit: April 27, 2018, 10:08:05 pm by Arshad »
