Author Topic: Generating element type: Table in VBscript  (Read 5121 times)
qal
« on: February 02, 2017, 09:50:52 pm »
I was trying to generate some tables with Vbscript and I was using command: EA.Package.Elements.AddNew("name",[type]) , but it seems that there is no type "Table" to choose. Is there a way to create new element as table by script, or for example create class element and afterwards alter it to Table ?
Also are there any important differences between Class object with stereotype table and Table object ? Because i've already got some table objects in my project (they were createdy by right clicking on package and choosing "Add Element..." -> Table) and I want them to be consistent with new table objects created by scripts, but if there is no significant differences maybe I don't need them to be exact the same ?
And my EA version is 12.1
I would appreciate any hints.
Pawel
Re: Generating element type: Table in VBscript
« Reply #1 on: February 03, 2017, 01:54:03 am »
Probably it's enough to create a Class and assign it the stereotype "table".
« Reply #2 on: February 03, 2017, 05:55:27 am »
It is, just make sure you use StereotypeEx to assign the stereotype.
Also make sure to set the Element.GenType to the database type.
qal
« Reply #3 on: February 03, 2017, 06:07:19 pm »
Ok, Thanks for the info.
