Author Topic: Adding Connector using API and Manually  (Read 7332 times)
Eamonn John Casey
« on: February 02, 2017, 10:58:39 pm »
I got a problem where I create a Connector through the API and create the same Connector manually. The API Version shows the stereotype in the diagram. The manual one shows the text I want to show. I have create my own MDG.
The code looks like this:
public EA.Connector FindorCreateConnector(string fromElementGUID, string toElementGUID, string connectorType, string connectorDirection, string connectorStereoType)
    EA.Element fromElement = eaRepository.GetElementByGuid(fromElementGUID);
    EA.Element toElement = eaRepository.GetElementByGuid(toElementGUID);
    EA.Connector connectorFound = null;
    foreach (EA.Connector connector in fromElement.Connectors)
        if (connector.SupplierID == toElement.ElementID)
            connectorFound = connector;
    if (null == connectorFound)
    connectorFound = (EA.Connector)fromElement.Connectors.AddNew("", "Connector");
        connectorFound.Type = connectorType;
        connectorFound.Stereotype = connectorStereoType;
        connectorFound.SupplierID = toElement.ElementID;
        connectorFound.Direction = connectorDirection;
        connectorFound.Update();
    return connectorFound;
Calling it like this:
FindorCreateConnector(fromGUID, toGUID, "association", "", "NAV_Begrep::relatertTil");
Any ideas what is missing?
Re: Adding Connector using API and Manually
« Reply #1 on: February 03, 2017, 02:30:52 am »
No idea, but your creation of the connector is strange, since the 2nd parameter from the addNew is supposed to take the connector type.
connectorFound = (EA.Connector)fromElement.Connectors.AddNew("", connectorType);
« Reply #2 on: February 03, 2017, 04:45:11 am »
Try StereotypeEx instead of Stereotype. I believe that usually works a lot better.
Nabil
    • View My LinkedIn Profile Here
« Reply #3 on: February 03, 2017, 04:32:22 pm »
No need to change Stereotype,
Try Adding this line after update, should work
fromElement.Connectors.Refresh();
BR,
Nabil
« Last Edit: February 03, 2017, 04:33:53 pm by nabil_EA_consultant »
Nabil
Eamonn John Casey
« Reply #4 on: February 03, 2017, 06:36:04 pm »
Thanks. Let you know what the solution is.
« Reply #5 on: February 03, 2017, 08:12:07 pm »
@nabil The Refresh operation just updates the collection after changes and it is needed only if you want to iterate over it in the later program text.
Eamonn John Casey
« Reply #6 on: February 08, 2017, 08:29:21 pm »
Turns out I was over complication Things as usual. Here is the corrected code that does work:
public EA.Connector FindorCreateConnector(string fromElementGUID, string toElementGUID, string connectorDirection, string connectorStereoType)
foreach (EA.Connector connector in fromElement.Connectors) {
if (connector.SupplierID == toElement.ElementID) {
if (null == connectorFound) {
connectorFound = (EA.Connector)fromElement.Connectors.AddNew("", connectorStereoType);
