Author Topic: How to Auto generate component diagram out of existing java source code  (Read 6060 times)
gokula
Do EAv12 provides ways to autogenerate component diagrams out of existing java source code.
Please help me how can i generate component diagrams out of java source code.
Re: How to Auto generate component diagram out of existing java source code
« Reply #1 on: February 05, 2017, 07:49:45 am »
No, that's not possible. However, if you reverse engineer your Java source, EA can generate a package structure which you can use to create component diagrams. It's even possible to use the API to support that process. But that only makes sense if you do that on a regular basis. For a one-time job it's easier to do it manually.
