Author Topic: Document Generation: "Hide Note-Less Elements" DOESN'T  (Read 5666 times)
amyfens
« on: February 07, 2017, 03:40:46 am »
Hi all,
I'm trying to generate a document with various diagrams (both BPMN and UML included), and when I try to filter out the empty elements by checking "Hide Note-Less Elements", the note-less elements still appear in the generated document.
Might this be an issue with the way the BPMN package is implemented in the program? Any other ideas/suggestions? Getting frustrated with an unnecessarily cluttered document.
Amy
Paul Lotz
Re: Document Generation: "Hide Note-Less Elements" DOESN'T
« Reply #1 on: April 26, 2017, 05:33:28 am »
Is there any more information on this?
I also am seeing elements without notes in documents generated from my UML and SysML models (EA Build 1107). Previously generated versions of the same document did not have this issue. I am using model documents, so this should be highly repeatable.
Paul Lotz
« Reply #2 on: April 26, 2017, 07:47:57 am »
I found the problem in my case. The template I was using has its own Document Options, which apparently were overriding my selection in the Generate Documentation dialog.
