Author Topic: Connecting w VBA - Error - "Object variable or With block variable not set"  (Read 6899 times)
filipepinto
I'm trying to connect to a MS-SQL instance using VBA (from within MS-Word) but I'm getting the error "Object variable or With block variable not set".
This is the code that I'm using:
Sub GetSparxElements()
' Returns the list of elements from a Repository
[code]Dim Repository As EA.Repository
Dim ConnectString As String
ConnectString = "SPARX --- DBType=1;Connect=Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=SPARX;Data Source=X-CPROD270;LazyLoad=1;"
bool = Repository.OpenFile(ConnectString)
End Sub
Rings a bell?
Thanks!
You'll need to create the Repository object before you can use it.
Should look something like this:
Set Repository = new EA.Repository()
filipepinto
Hey Simon,
Thank you for your answer.
I'm using VBA. Doesn't the Dim instantiates the variable?
No. It only defines the space (or more specific the reference) for the object.
« Last Edit: February 08, 2017, 09:22:20 am by qwerty »
I'm far from an expert at VBA, but your although the error message is typically cryptic it interpreted as the need to create the object.
http://sparxsystems.com/enterprise_architect_user_guide/13.0/automation/setup.html
The VB6 instructions use a Dim with New.
filipepinto
Thanks Simon - that solved it! ;D
