Author Topic: Exporting Relationship Matrices to Word  (Read 14533 times)
Polymorph
« on: February 10, 2017, 03:13:51 am »
Has anyone found a way to create a document template that exports a relationship template to Word? I can get EA to print out a JPEG of the matrix easily enough but this is totally useless because it is so tiny as to be completely illegible. Does this require some kind of Ninja SQL skills?
Obviously there's the CSV export option from the Relationship Matrix itself but this has its own problems because it only outputs the names of the elements and none of their detailed attributes such as their notes.
I am performing requirements traceability and am amazed that this functionality seems to be so lacking!
PeterHeintz
Re: Exporting Relationship Matrices to Word
« Reply #1 on: February 10, 2017, 03:16:22 am »
I assume you need the Ninja SQL skills.
Best regards,
Peter Heintz
Nabil
    • View My LinkedIn Profile Here
« Reply #2 on: February 10, 2017, 05:49:58 pm »
Try Custom Template with scripting guess that is the only way to acheive what you expect.
Best Regards,
Nabil Saleem
Nabil
« Reply #3 on: February 10, 2017, 09:04:52 pm »
It's going to need some kind of Ninja skills, but I think you will probably need a document script template to be able to vary the number of columns in your table.
So you'll need to make a script that outputs raw RTF that contains the table with the contents you need.
Polymorph
« Reply #4 on: March 09, 2017, 10:21:20 am »
Thanks guys
Why on Earth isn't this something EA supports?!? Seriously, who wants a JPEG of a relationship matrix!!
« Reply #5 on: March 09, 2017, 03:54:26 pm »
Thanks guys
Because someone put it on the backlog and one of the juniors took the ticket and didn't know any better because the requirements were not clear.
Happens all the time in all development teams  :-X
pb17
« Reply #6 on: June 01, 2023, 01:21:03 am »
I´m having the exact same problem. Has anyone found a possible solution to this issue?
I´m trying the RTF template and the custom script approach, but it is getting more complex. I can create an XML structure of the matrix but I'm failing to understand how to export it in a fragment.
Thank you in advance.
« Reply #7 on: June 01, 2023, 02:22:20 am »
The only feasible solution is to export the same data in a fixed column layout using an SQL fragment:
see also https://stackoverflow.com/questions/76359145/how-to-export-a-relationship-matrix-in-a-document
If you really really wanted to, you'd have to somehow craft an RTF string containing the contents of your matrix.
I'm not sure how you'd do that, but RTF is textual format. If you use wordpad to create a table with a few rows and columns, and save it as .rtf, you can open it with notepad and see how it looks in RTF.
then work back from there I guess...
Good luck  ;D
Sunshine
  • Its the results that count
« Reply #8 on: June 01, 2023, 07:47:47 pm »
I resorted to post editing a word document by exporting the matrix to CSV, opening in MS Excel then copy and pasting into MS Word.
Happy to help
Thomas Arnbjerg
« Reply #9 on: June 02, 2023, 07:15:27 pm »
I normally create a javascript script, which generates new 'report friendly' trace elements in the model followed by a report template to create the Word Document..
