Author Topic: ShapeScript for BPMN activity  (Read 35426 times)
Viking
« on: February 11, 2017, 12:12:58 am »
I want to display a process step as BMPN activity in one diagram and as Achimate process step in another with shape scripts (of if EA provides something else in the meantime than somethings else).
I learned that this is possible. I am able to create simple shape scripts. But the BPMN activite can be shown in many different ways and I do not have an idea how to implement this.
Suggestions are very welcome. Please do not discuss if this makes sense or not.
Thank you in advance, V.
Re: ShapeScript for BPMN activity
« Reply #1 on: February 11, 2017, 12:26:19 am »
You are another one looking for schizophrenic element (can't remember who was the other guy starting a longish discussion here). An element is what it is. Either one thing or another. I guess you are just tackling your problem from the wrong side here.
« Reply #2 on: February 11, 2017, 01:17:39 am »
Viking
« Reply #3 on: February 11, 2017, 01:32:50 am »
You are another one looking for schizophrenic element (can't remember who was the other guy starting a longish discussion here). An element is what it is. Either one thing or another. I guess you are just tackling your problem from the wrong side here. q.
An element is an element and a notation is a notation. A notation just shows an element with a specific shape. An element could be shown by a circle or by a rectangle. It's still the same element.
« Reply #4 on: February 11, 2017, 02:04:17 am »
Viking
« Reply #5 on: February 11, 2017, 05:45:01 am »
It appears that it was you: http://sparxsystems.com/forums/smf/index.php/topic,37317.msg234563.html#msg234563
I'm out here. q.
It does not appear, that it is me. It is me. That's why I did not want you to start the discussion.
While I told you my arguments, you did not tell me your arguments. So why did you start the discussion again?
« Reply #6 on: February 11, 2017, 08:17:06 am »
Aliens are so funny - Can someone please turn on Country music?
« Reply #7 on: February 13, 2017, 09:15:33 am »
Here's a starting point for creating the pictures you want.
shape main
layouttype="border";
if(hasproperty("diagram.mdgtype", "ArchiMate3::Application"))
AddSubShape("ProcessStep","center");
else if(hasproperty("diagram.mdgtype", "BPMN2.0::Business Process"))
AddSubShape("Activity","center");
else
AddSubShape("DiagramType","center");
shape ProcessStep
ellipse(0,0,100,100);
println("#name#");
shape Activity
roundrect(0,0,100,100,10,10);
println("#name#");
shape DiagramType
rectangle(0,0,100,100);
println("#diagram.mdgtype#");
println("#diagram.stereotype#");
println("#diagram.type#");
Glassboy
« Reply #8 on: February 13, 2017, 10:43:30 am »
Not Country but may be a little bit of psychobilly? https://www.youtube.com/watch?v=7I8pC_DOXC4
« Reply #9 on: February 13, 2017, 05:59:09 pm »
Viking
« Reply #10 on: February 13, 2017, 07:27:14 pm »
I rather was after this: https://www.youtube.com/watch?v=aTe0MjAZvMU
Dear qwerty, dear classboy, Thank you very much for these arguments. Regards V
Viking
« Reply #11 on: February 13, 2017, 07:31:34 pm »
Viking
« Reply #12 on: February 13, 2017, 07:32:36 pm »
shape main
else
shape ProcessStep
println("#name#");
shape Activity
println("#name#");
shape DiagramType
Dear Simon, Thank you. This is in the right direction. I am looking for a property, which tells the scripts, that the BPMN-element is for example executed automatically or by hand (and all the other possible properties). So the shape-script should not only decide, that the element is a BPMN activity. It should further identify, which kind of BPMN activity it is and than using the correct BMPN activity shape (e.g. gear-wheels for an automated service or a hand for manually).
« Last Edit: February 13, 2017, 09:24:05 pm by Viking »
« Reply #13 on: February 14, 2017, 08:32:48 am »
Replace the Activity subshape with the contents of the script Geert referenced. Replace the ProcessStep subshape with the appropriate script from the same repository.
Viking
« Reply #14 on: February 15, 2017, 06:57:35 pm »
Hello Simon,
Thank you very much.
The result of my attempt was not as expected. That's why I tried the plain scrpts of Geert. I tried Enterprise-Architect-Shapescript-Library / Archimate2 / ArchiMate_BusinessProcess.shapeScript. It does not show the process icon on the top right (even not in the preview). I tried the same for BPMN Activity and it looked also differently to the original one.
Following questions arose:
(1) The scripts from Geert seem to be extracted from EA. Why are the icons not shown?
(2) Within the properties of an element I can assign several stereotypes. What is the impact of conflicting stereotypes?
(3) What is the impact of BaseClass on the UML-types editor to the ShapeScript?
Many thanks in advance, V,
« Last Edit: February 15, 2017, 09:19:33 pm by Viking »
