Author Topic: Show constraints on a "Realization"  (Read 4134 times)
cgreuter
« on: February 13, 2017, 11:43:26 pm »
hey there,
I am using constraints to dokument some aspects on a "Realization" between two classes.
On a diagram, i would like to show these constraints, similar to the way constraints are shown in an Assiciation.
However i cannot figure out how the Constraint  can be made visible on a diagram.
any hints on this topic?
best regards
PeterHeintz
Re: Show constraints on a "Realization"
« Reply #1 on: February 14, 2017, 02:15:12 am »
To what did you put the constraints?
If you e.g. put it to a class, select the element in the diagram. Press right mouse button, select Features & Properties/Feature and Compartment Visibility… and tick Constraints.
Best regards,
Peter Heintz
« Reply #2 on: February 14, 2017, 03:34:54 am »
You can't show them on a diagram :-/ However, what you can do is to create a constraint element from the toolbox (context menu/Common), fill that out and then from the context of this constraint issue Advanced/Set Attached Links and tick the connector where you want it.
cgreuter
« Reply #3 on: February 15, 2017, 01:46:11 am »
Hey qwerty & Peterheintz
Thank you very much for your replies.
I was using  the constrains on a "realize" connection, not on a class. The solution mentioned by qwerty worked for me.
Best regards
C
