Author Topic: Create and add Hyperlink from diagram to diagram  (Read 4127 times)
Markus Bauernfeind
« on: February 15, 2017, 11:40:11 pm »
How do I create an Hyperlink from a diagram to be placed into an other diagram using the add-in mechanism.
Re: Create and add Hyperlink from diagram to diagram
« Reply #1 on: February 16, 2017, 02:20:43 am »
A bit tricky (like so many things in EA). You need to create a Text element and set t_object.PDATA1 to the diagramId you want to link. The latter must be done with a SQL (use Repository.Execute) since the according MiscData from the API is r/o.
Markus Bauernfeind
« Reply #2 on: February 16, 2017, 06:20:10 pm »
Thank you for your quick reply. But how do I create a Text element?
« Reply #3 on: February 16, 2017, 07:20:25 pm »
As usual:
Package.Elements.AddNew("some name", "Text")
