Author Topic: Invoking inbuilt script through custom script  (Read 6339 times)
ashwinimore
« on: February 16, 2017, 11:38:37 pm »
Is it possible to invoke an inbuilt script e.g. export xsd script from a custom Jscript ?
Ashwini
Re: Invoking inbuilt script through custom script
« Reply #1 on: February 17, 2017, 12:08:12 am »
Do you mean the function to export an xsd, or an actual script that exports an xsd?
I don't think the export xsd function is available from the API.
If you want to execute script from a script, that is possible, but not an easy task.
See https://github.com/GeertBellekens/Enterprise-Architect-Add-in-Framework/blob/master/EAAddinFramework/EASpecific/Script.cs for a working C# example.
ashwinimore
« Reply #2 on: February 17, 2017, 12:32:59 am »
I have my own custom script, I want to generate XSD by passing the schema name from the model
same as we do by using the generate schema option.
Is it possible to do, if yes could you please suggest how to do it?
Or is there any alternate way to do it?
I am using EA 13.
Ashwini
« Reply #3 on: February 17, 2017, 04:42:04 am »
As I said, the generate xml schema functionality is not exposed by the API so you can't call that using a script.
The API  and all of its functions is documented here: http://sparxsystems.com/enterprise_architect_user_guide/13.0/automation/reference.html
« Reply #4 on: February 17, 2017, 08:35:02 am »
Actually, it's really easy:
!INC [Script Group Name].[Script Name]
It's easier but not a requirement if the script being included is only defining functions that you can explicitly call.
http://sparxsystems.com/enterprise_architect_user_guide/13.0/automation/project_2.html
GenerateXSD (string PackageGUID,
string FileName,
string Encoding,
string Options)
« Last Edit: February 17, 2017, 08:39:24 am by Simon M »
ashwinimore
« Reply #5 on: February 17, 2017, 04:40:31 pm »
Thank You for your response.
I am able to generate the XSD using Repository.GetProjectInterface().GenerateXSD
« Reply #6 on: February 17, 2017, 06:26:29 pm »
string FileName,
string Encoding,
string Options)
I stand corrected  :-[
I guess I was thinking about the import xsd feature
