Author Topic: Api to know which user have locked the object  (Read 3326 times)
kotrick
« on: September 05, 2011, 01:50:36 pm »
hi,
if i try to lock an object in EA through automation which is already locked by other user then i get an exception .so is there any way or api to identify whether i can lock that object or not.i.e. is there any api to identify who has locked the object
Re: Api to know which user have locked the object
« Reply #1 on: September 06, 2011, 05:44:27 pm »
The only way I found was by querying the database directly.
Here's the code I use:
/// <summary>
        /// returns the name of the user currently locking this element
        /// </summary>
        /// <returns>the name of the user currently locking this element</returns>
        public override string getLockedUser()
            string lockedUser = string.Empty;
            //if (this.wrappedElement.Locked)
                string SQLQuery = @"select u.FirstName, u.Surname from t_seclocks s
                                    inner join t_secuser u on s.userID = u.userID
                                    where s.entityID = '" + this.wrappedElement.ElementGUID + "'";
                XmlDocument result = ((EAModel)this.model).SQLQuery(SQLQuery);
                XmlNode firstNameNode = result.SelectSingleNode("//FirstName");
                XmlNode lastNameNode = result.SelectSingleNode("//Surname");
                if (firstNameNode != null && lastNameNode != null)
                    lockedUser = firstNameNode.InnerText + " " + lastNameNode.InnerText;
            return lockedUser;
