Author Topic: Connection lines intersection  (Read 11450 times)
ralfeus
« on: February 21, 2017, 06:33:13 pm »
Hi.
I have noticed the elements connection lines intersection isn't always shown as one. Sometimes it shows intersection (as a semicirle) but more often it doesn't. Is it a bug or rather caused by connection type (I mostly use ArchiMate extension's ones)?
Re: Connection lines intersection
« Reply #1 on: February 21, 2017, 08:45:16 pm »
It should work for straight lines. Dashed lines do not create hops. I'm not sure about stereotyped lines that have a shape script, but would suspect issues in that area.
ralfeus
« Reply #2 on: February 21, 2017, 08:58:23 pm »
Can intersection be defined by shape script?
« Reply #3 on: February 21, 2017, 11:17:40 pm »
No. That's all done by the renderer. That reminds me that the Options offer different renders. No idea on how they influence the result.
P.S. No influence from the different renders.
« Last Edit: February 21, 2017, 11:19:19 pm by qwerty »
ralfeus
« Reply #4 on: February 22, 2017, 12:59:14 am »
So do I understand correctly the fact intersections of same relation types sometimes are shown and sometimes aren't can be considered as a bug and reported accordingly?
« Reply #5 on: February 22, 2017, 01:47:51 am »
Hard to tell, without seeing details. But you can report that anyway if you think it's buggy. Eventually it's considered as new feature. Or they point you to the documentation.
Glassboy
« Reply #6 on: February 24, 2017, 12:54:50 pm »
I don't think what you are saying is quite true.  Two solid lanes will intersect with a hop.  Non-solid lines won't.  I can't think of an instance where a relationship will be shown with both a solid and non-solid line on the same diagram.
« Reply #7 on: February 24, 2017, 06:10:40 pm »
We have a couple of custom relationships that are solid for the 1st 50% and then not solid for the second 50%.  Like the old Oracle Data Modelling notation.
But I suspect that's not what you were talking about.
Glassboy
« Reply #8 on: February 27, 2017, 08:58:25 am »
I was talking about standard notation relationships, not your post truth relationships.
ralfeus
« Reply #9 on: February 27, 2017, 08:54:04 pm »
Doesn't happen.
Can it be valid example? It's standard ArchiMate modelling.
« Reply #10 on: February 27, 2017, 09:06:17 pm »
What I guessed. The connectors you used are (Archimate-) stereotyped. And they have an underlying shape script. Obviously this shape script does not render hops. You might send a feature request. Or maybe have a beer to drown your disappointment.
ralfeus
« Reply #11 on: February 27, 2017, 09:34:13 pm »
Yeah, I'll need a lot of beer :-)
Thank you for make things clear.
Glassboy
« Reply #12 on: February 28, 2017, 07:54:46 am »
I had a look at the Archimate specification.  It seems to be silent on hops.
