Author Topic: Addition/subtraction in DLL templates ?  (Read 4504 times)
qal
« on: February 21, 2017, 06:42:59 pm »
Is there a way of making addition or subtraction operations inside DDL template ? I was trying to get some substring and i find out that typing $numvariableA - $numvariableB just results in a string output with minus in it. I find workaround, but its a little weird and it will be better if i just could use a subtraction.
Thanks in advance,
Qal
Re: Addition/subtraction in DLL templates ?
« Reply #1 on: February 21, 2017, 08:48:17 pm »
I always recommend to just ignore this awkward scripting and use the API for transformation and code generation. That will not limit you in such basic things. It's a greater start-up since you start at scratch. But once you have some scaffold you can do much much more.
qal
« Reply #2 on: February 22, 2017, 06:10:17 pm »
Ok, Thanks for the advice. I'm gonna try it out :}
Aaron B
« Reply #3 on: February 27, 2017, 12:44:05 pm »
Hi Qal,
There are actually function macros available in the code gen / transformation templates for MATH_ADD, MATH_SUB and MATH_MULT.  Unfortunately they don't seem to be documented though.  We will look into getting the help updated.
MATH_ADD(x, y)
Returns the value of x+y.
MATH_MULT(x, y)
Returns the value of x*y.
MATH_SUB(x, y)
Returns the value of x-y.
Note: x and y for above parameters can be passed as either numerals or strings.  E.g. %MATH_ADD("10", "2")% returns 12.
