Author Topic: QA Reports Filters do not function correctly  (Read 5353 times)
Paul Lotz
« on: February 24, 2017, 04:35:57 am »
I have tried to use this feature for some time, and it hasn't worked. I thought maybe I just wasn't understanding how to use it, but it seems pretty clear to me I am using it as one would expect it to work. I filed the following report.
"I want to filter the use cases that appear in the Use Cases in the QA Reports. I should be able to do this using the "Keyword like" button. (From the help: "Include Use Cases with a keyword that matches the wildcard value in the field.")
The actual behavior is not thus, however. For instance, entering a valid keyword in the "Keyword like" field (and clicking Reload) returns 0 results. This is true even if the value is '*'.'
This functionality would be very useful if it worked correctly. Please fix it."
Paul Lotz
Re: QA Reports Filters do not function correctly
« Reply #1 on: February 24, 2017, 11:38:51 am »
OK, EA support already replied to me. The "Keyword like" search uses the "Keywords" property of the Use Case. (That does make sense, after all.) I mistakenly thought it searched in the use case names. So this is user error on my part rather than a bug. Now I know how to use the feature.
Paul
