Author Topic: Sparx errors on open. Error in xml file  (Read 9987 times)
adama
« on: February 26, 2017, 03:33:20 am »
I get this message when I open the softare:
"Error:
Code=0xc00ce557
Source=Line : 2; Char : 3
Error Description = Invalid xml declaration."
I deleted all my xml files I could find, but I still get it. What's going on? Any ideas?
Re: Sparx errors on open. Error in xml file
« Reply #1 on: February 26, 2017, 04:50:36 am »
Is this your first approach to MDG? I have a write-up for MDG here which might be helpful: http://liquit.biz/brain/enterprise.html
« Last Edit: March 18, 2017, 04:18:53 am by qwerty »
adama
« Reply #2 on: March 18, 2017, 02:46:45 am »
qwerty, I get this error when I open Sparx.  I don't know which file it comes from. I deleted everything in %APPDATA%\Roaming\Sparx Systems\EA\MDGTechnologies.  I get this error every time I open Sparx, no matter how I open it.
« Reply #3 on: March 18, 2017, 04:20:49 am »
Go to Extensions/MDG and turn off all MDGs and see whether you still get the error. Then turn them on one by one.
adama
« Reply #4 on: March 18, 2017, 09:12:08 pm »
SOLVED!!!!!
  • On Ribbon Menu, went to Configure->Manage Technology.
  • On MDG Technologies window->Select Advanced button.
  • Under "Specify MDG Technology paths & URLs", I had the wrong path. Deleted path.
    Closed and restarted
Problem gone. :)
« Last Edit: March 18, 2017, 09:56:35 pm by adama »
« Reply #5 on: March 20, 2017, 11:10:57 am »
SOLVED!!!!!
Problem gone. :)
As I think you have discovered, EA will (naturally enough) attempt to open any *.xml file it finds in the referenced folder.  If any have errors or aren't MDG files...  "BAM!"
« Reply #6 on: March 20, 2017, 05:37:35 pm »
And why tell the user something like "File XY had an error" ?
« Reply #7 on: March 21, 2017, 03:04:38 am »
And where's the fun in that? That would mean every Joe and Jane could be solving mystical error messages. That would completely take the "wizard" status away from me 8)
