Author Topic: Configuring EA 13 to use OpenModelica  (Read 4553 times)
peterc
« on: February 27, 2017, 08:21:43 pm »
I have installed OpenModelica (the latest version - v1.11.0-64bit). As per the instructions in the EA guide I can locate the omc.exe file. However, in EA the option to configure the location of OpenModelica is greyed out - In the SysMLSim Configuration Manager only the "Select Artifact" option is available and all other options are greyed out, including the key "Configure Modelica Solver" so I cannot define where the OpenModelica EXE file is located.
Has anyone got any tips on why I cannot configure EA to use OpenModelica?
EA is the Corporate edition, with a floating licence and also have the SysML MDG Technology licence installed.
I can also run OpenModelica by itself (outside of EA).
Takeshi K
    • Sparx Systems Japan
Re: Configuring EA 13 to use OpenModelica
« Reply #1 on: February 28, 2017, 10:39:04 am »
Hi peterc,
Unfortunately, OpenModelica integration works only on Enterprise Architect Suite Systems Engineering edition or Ultimate edition.
http://sparxsystems.com/products/ea/compare-editions.html
You need to upgrade to these editions to use this feature.
t-kouno
