Author Topic: Base Class  (Read 5329 times)
Viking
Base Class
« on: March 01, 2017, 10:46:26 pm »
Could somebody explain to me the concept behind Base Classes in UML types, please?
Many thanks in advance, V.
Re: Base Class
« Reply #1 on: March 01, 2017, 11:19:40 pm »
If you explain what you mean by UML types.
The only UML reference I found is on pp. 259:
The name of the Property typed by the extended metaclass is:
‘base_’ extendedMetaclassName
The name of the Property typed by the extension Stereotype (the ExtensionEnd) is:
‘extension_’ stereotypeName
Constraints are frequently added to Stereotypes. The above Properties may be used for expressing OCL navigations. For example, the following OCL expression states that a Home Interface shall not have attributes:
       self.base_Interface.ownedAttributes->isEmpty()
Viking
Re: Base Class
« Reply #2 on: March 02, 2017, 02:52:53 am »
Project > Settings > UML Types.
Here I implement stereotypes and shape scripts.
Viking
Re: Base Class
« Reply #3 on: March 02, 2017, 02:59:53 am »
I am as confused as before :-)
Re: Base Class
« Reply #4 on: March 02, 2017, 07:31:34 am »
"UML types" in that context is a Sparx invention for predefined Stereotypes, Tagged Values and whatever one likes to appear in the cardinality drop downs.
Re: Base Class
« Reply #5 on: March 02, 2017, 09:15:27 am »
If you want to define a global stereotype that extends Class, for example, you type "class" in the Base Class field. By global stereotype, I mean a stereotype that isn't part of a UML Profile. Most of the values for Base Class will be UML metaclasses, but there are some exceptions (e.g. "requirement") that you can pick up as you go.
