Author Topic: Report generation - Use Cases and wireframes  (Read 5069 times)
tjlindsay
« on: March 03, 2017, 03:05:37 am »
The problem I am trying to solve and to some degree it has been done - it just be that I might have missed a trick, but I want to produce a use case report which contains the following:
1. Use Case context model
2. Use Case description including happy, normal and exception flows
3. Use Case activity diagram
4. Wireframes traced to the specific use case
The information published here is exactly what I a after.
https://zubkiewicz.com/nonlinear-generation-of-documentation-in-sparx-enterprise-architect/
Unfortunately I cannot on generating the document get the wireframes to output into the report.
I assume there is something minor that I have missed (or maybe not), but would welcome help to rectify the problem.
As always, many thanks for the continued support.
jfzouain
Re: Report generation - Use Cases and wireframes
« Reply #1 on: March 04, 2017, 01:53:33 am »
Hi
There is a way to do all that and is after creating these packages, you want to include them in your Master Template, I explain all this with detail how to do it.
It will be a long thread explaining all the detail you need to know as a Novice User of EA.
Look at my eBook "UML-ERP Workshop - Writing a Business Requirement Document with EA" for further information at Leanpub.com.
https://leanpub.com/uml-erpworkshop
Best regards
Jose
Best regards
Jose Zouain
tjlindsay
« Reply #2 on: March 09, 2017, 02:03:46 am »
Excellent - thanks Jose.  ;)
TJ.
