Author Topic: MDG Technology - Stereotype - Linked Document  (Read 9055 times)
rvi1cob
« on: March 06, 2017, 05:06:32 am »
Hello Everyone,
I am looking for a possible option for the below scenario.
I have a set of stereotypes defined in my MDG technology. Each of it has to be associated with its own "Linked document" template. I created as set of linked documents along with the MDG Technology.
After the technology is imported:
Is there any way when I create an element of the defined stereotype, the linked document is associated by default to a linked document template?
The reason is I have multiple stereotypes and each should use its own linked template. It would be weary to go through a list of document template otherwise.
Regards
Vijay
Uffe
Re: MDG Technology - Stereotype - Linked Document
« Reply #1 on: March 06, 2017, 07:57:23 pm »
Hi Vijay,
First off, this question is better posted in the Automation Interface, Add-Ins and Tools forum.
In answer to your question, I don't think there's a way to achieve that using just MDG Technologies. You can do it by building an Add-In, which responds to the EA_OnPostNewElement event by checking the stereotype of the newly created element and creating the appropriate linked document.
Note that creating a linked document through the API requires loading the document from a file, so you'd need your template stored in the file system -- not in the MDG Technology or the EA project -- for this approach to work.
/Uffe
« Reply #2 on: March 07, 2017, 08:41:36 am »
You can do what you are wanting by adding a single element pattern to the toolbox instead of a stereotype.
http://sparxsystems.com/enterprise_architect_user_guide/13.0/modeling_tools/toolbox_profiles.html
