Author Topic: Display of element tags when instanced  (Read 5135 times)
jankari
« on: March 10, 2017, 03:00:45 am »
I am using EA with shared repository (SQL Server). I have a global catalog of elements and the elements have tags and tag values defined. I have a package with a specific solution in it. I have a diagram within this solution and the diagram property is set to show tags. In this diagram, when I use an element from the global catalog as a "link" it shows the tags whereas if I use it as an "instance" then the tags don't appear even though in the instanced element's property window the parent tag is visible.
Anyone know why instanced elements tags aren't visible in diagrams?
Thank you in advance for your time and input.
Re: Display of element tags when instanced
« Reply #1 on: March 10, 2017, 08:09:42 am »
I had no issue setting "Show inherited tags" for an instance to see the classifier's TVs.
jankari
« Reply #2 on: March 10, 2017, 08:42:09 am »
Thanks querty. Where did you see that option (Show Inherited Tags)?
« Reply #3 on: March 10, 2017, 10:09:32 am »
Context menu in diagram: Features/..Visibility... the check marks on the right side.
jankari
« Reply #4 on: March 11, 2017, 01:07:59 am »
I am using v12. I did look at Diagram > Properties > Features before but I don't see it there.
Thank you
Uffe
« Reply #5 on: March 11, 2017, 01:23:11 am »
You're in the context menu for the diagram there. It's in the context menu for the element in the diagram.
/Uffe
jankari
« Reply #6 on: March 11, 2017, 01:42:10 am »
Found it :) Thank you!
