Author Topic: If-Or-Statement within Shape Scripts  (Read 44202 times)
Viking
Re: If-Or-Statement within Shape Scripts
« Reply #15 on: March 16, 2017, 05:52:47 pm »
I believe what qwerty is saying is that you cannot do text or value comparisons in ShapeScript.  There is no "if ( a=1 )" syntax.  There is only "if (hasproperty(a))"
I thought the pseudo-code would make the issue easier to undertand. I did not. I am sorry.
I need someting like:
shape main
   layouttype="border";
   if(hasproperty("diagram.mdgtype", "BPMN1.0::Business Process") OR hasproperty("diagram.mdgtype", "BPMN2.0::Business Process") )
      AddSubShape("Activity","center");
Viking
« Reply #16 on: March 16, 2017, 06:03:36 pm »
Yes, the language is simplistic.
I've handled this is the past by reversing the logic.
if (a!=1) {
   if (a!=2)   {do XY}
Could be that I do not understand the point. Could you translate this into my example, please?
shape main
  else if(hasproperty(...)
« Reply #17 on: March 16, 2017, 07:59:25 pm »
No. There is no AND. There is no OR. Look at Simon's example how to code a work around for the AND. It's simple Boolean algebra and use of copy and paste.
Viking
« Reply #18 on: March 16, 2017, 08:05:30 pm »
No. There is no AND. There is no OR. Look at Simon's example how to code a work around for the AND. It's simple Boolean algebra and use of copy and paste. q.
I was not asking for AND. I was asking for OR. If Simon's example reflects AND, than this is no solution for my issue. If Simon's example reflects OR, than I do not understand how to copy and paste it into my example.
« Reply #19 on: March 16, 2017, 10:27:51 pm »
In that case you might need to do something like
shape main
 if hasproperty("diagram.mdgtype", "BPMN2.0::Business Process")
That would means some duplicated code, but it would work. It would make things easier if we could use NOT, AND and OR, but where's the challenge then right  ;D
Viking
« Reply #20 on: March 16, 2017, 11:54:23 pm »
shape main
This is what we are doing at the moment. But the issue is in the SubShapes where we are using a lot of code. And this code has to be dublicated several times.
« Reply #21 on: March 17, 2017, 10:22:04 am »
It has been said more than once here, that there is no OR. There are also no functions/procedures. There is just COPY and PASTE. The way you do it is the only way. Capisce?
« Reply #22 on: March 17, 2017, 03:07:24 pm »
You'll either need to duplicate the conditions or the bodies.
shape main
    if(hasproperty("diagram.mdgtype", "BPMN1.0::Business Process")) {} else
        if(hasproperty("diagram.mdgtype", "BPMN2.0::Business Process")) {} else
            if(hasproperty(...)
Although I would just ignore the possibility of BPMN 1.0 diagrams. Make your life a bit easier.
So long as Simon meant "too simple to work properly" - which is the corect meaning of "simplistic".
I meant that the simplicity makes some things unnecessarily difficult. It works. Although you may argue that it doesn't because it doesn't offer some capabilities that you would like to see.
Glassboy
« Reply #23 on: March 20, 2017, 01:55:09 pm »
Given that the OP is trying to do something that everyone advised him not to do, I think this whole conversation is down the rabbit hole anyway.  :-)
Viking
« Reply #24 on: March 20, 2017, 11:13:27 pm »
It has been said more than once here, that there is no OR. There are also no functions/procedures. There is just COPY and PASTE. The way you do it is the only way. Capisce? q.
Many thanks, Thomas.
Viking
« Reply #25 on: March 20, 2017, 11:20:14 pm »
No. There is no AND. There is no OR. Look at Simon's example how to code a work around for the AND. It's simple Boolean algebra and use of copy and paste.q.
We are using AND and it works as intended :)
Yes, there is no OR or XOR in the way we need it.
I did not know that everybody told me. Many thanks for telling me.
