Author Topic: MDG: Generailzation and Extension  (Read 13273 times)
Viking
« on: March 15, 2017, 01:28:27 am »
Hi together,
We created a MDG. A part of it is the new stereotype "Process Step" with an own shape script. Dependent on the diagram type it is used, the Shape Script shows a BPMN Activity or ArchiMate BusinessProcess. We have learned that we have to use Generalization and / or Extension. But we think we did not understand the concept behind it. The MDG does not work as expected.
Our questions are:
(1) Can a new stereotype (here "Process Step") use Extension to a (or several) meta class(es) and Generalization to a (or several) sterotype(s) in parallel?
(2) To which Stereotypes should we point Generalization of "Process Step" (currently we are using Archimate2::ArchiMate_ApplicationComponent and BPMN2.0::Pool)?
(3) Is multiple Generalization possible (in our exampe above "Process Step" points to 2 sterotypes (see (2))?
(4) To which MetaClass should we point the Extension of "Process Step" (we tried "Class")? Or do we only need Generalization because the sterotypes we used for Generalization (see (2)) should have been extended a MetaClass already).
Many thanks in advance, V.
« Last Edit: March 15, 2017, 06:06:32 pm by Viking »
Re: MDG: Generailzation and Extension
« Reply #1 on: March 15, 2017, 11:25:23 pm »
I'm not sure about most of the questions, I guess you'll have to find out using trial and error.
I can give you an easy tip on the question which Metaclass to extend.
If you remove the stereotype of an element then only the Metclass remains. That is the metaclass to extend.
Viking
« Reply #2 on: March 16, 2017, 01:06:47 am »
Geert, many thanks.
Do you know, why EA creates the meta class, I create in a diagram by using Toolbox > Profile > Metaclass, also in the Project Browser? I expect just a link resp. a reference to the original one, which should be part of the system (so somewhere in the system resp. another folder, which is not accessible by the user). It seems to me that I get a copy.
Viking
« Reply #3 on: March 16, 2017, 03:31:57 am »
Very helpful. Tank you.
« Reply #4 on: March 16, 2017, 04:06:20 am »
Geert, many thanks.
There are no hidden system folders in EA, just some hard coded stuff.
Viking
« Reply #5 on: March 16, 2017, 04:25:32 am »
Geert, many thanks.
Is it not misleading that I get a copy or something else in my folder? EA says "extend metaclass". So what do I get? An extension (o.k., than I would undertand the copy) or a reference to the original metaclass?
« Reply #6 on: March 16, 2017, 11:37:58 pm »
Geert, many thanks.
What you get is a stereotype that is based on a certain metaclass. If you don't override any of the properties of the metaclass then your stereotype will behave exactly like the "plain" metaclass. So in that way you should look at it as a "generalization" in class diagram terms.
I honestly don't understand your confusion.
Viking
« Reply #7 on: March 17, 2017, 12:04:36 am »
I use Toolbox > Profile > Metaclass. I drag and drop metaclass into a diagram. I select the required metaclass from a list and the element gets displayed. EA shows this new element as a metaclass and not as a stereotype. It also add this element in my package.
You say "What you get is a stereotype". Really? As I said it is shown as a metaclass. And I thought that I just get a reference to something which is already there. I have the impression, that I get a copy, that extends or inherits from the original.
« Reply #8 on: March 17, 2017, 01:25:02 am »
Why do you use Metaclass from the toolbox?
All I ever needed to do what create stereotypes, and then link them to a metaclass using the profile helper.
Viking
« Reply #9 on: March 18, 2017, 04:57:37 am »
All I ever needed to do what create stereotypes, and then link them to a metaclass using the profile helper. Geert
We thought that we need a metaclass. But that was a mistake. Trial and error ...
