Author Topic: Element->Advanced->Context menu does not appear  (Read 7167 times)
adama
« on: March 18, 2017, 05:38:19 am »
Somehow, I lost this on all shape and diagram types.
1) Right-click on an Element.
2) Select Advanced.
Only thing that shows is "Tagged Value". None of the other cool features are present.
Please tell me what I did to cause this, and how to restore it.
Re: Element->Advanced->Context menu does not appear
« Reply #1 on: March 18, 2017, 06:50:21 am »
I have no idea. Does that happen on all elements? Have you turned on security? Is the diagram/element locked? Is the package VC/checked out?
adama
« Reply #2 on: March 18, 2017, 10:26:42 am »
It happens on most elements, including the ones I use most: UML, Archimate3, ZF.  It works on diagrams. It works for connectors. Does not work for most elements.
adama
« Reply #3 on: March 18, 2017, 10:00:50 pm »
1) Uninstalled and Re-installed the application. Problem persists.
2) I went into AppData\Roaming\Sparx Systems and deleted all the XML files in all subfolders.
Closed and re-opened app. No change. Problem persists.
3) Disabled all MDG technologies.
4) Enabled all MDG technologies.
5) Uninstalled and Re-installed the application. Problem persists.
6) Under Configure->Manage Technologies->Advanced, removed MDG paths. Problem persists.
7) Created a new model. Problem persists.
8] Tried same models on other systems. Problem does not happen on other systems.
9) Disabled all Add-ins. Problem persists.
10) Under Configure->Manage Technologies->Advanced, disabled all technologies and restarted. Problem persists.
11) Under Configure->Manage Technologies->Advanced, enabled all technologies and restarted. Problem persists.
« Last Edit: March 18, 2017, 10:12:40 pm by adama »
« Reply #4 on: March 18, 2017, 10:45:47 pm »
Look into View/Working Sets (where ever that might be in the ribbons) and check if everything is ticked.
adama
« Reply #5 on: March 19, 2017, 12:24:32 am »
Hi Qwerty. SOLVED. OPERATOR ERROR, it seems.
NOT A BUG! Somehow, my Menu Sets got changed to Reader, which disabled "MDA Transformation".
Restored to "Complete" profile, using "Workspaces and Commands" dialog, which I accessed by:
Ribbon->Start->Perspectives->Show Perspectives->Workspaces and Commands->Menu Sets.
Regrets,
-A
« Last Edit: March 19, 2017, 12:26:18 am by adama »
