Author Topic: Tagged Values aren't saved  (Read 4429 times)
royvanmarrewijk
« on: March 24, 2017, 03:18:19 am »
Every now and then I have the problem that the changes that I made to the tagged values of an operation won't be saved. So for example I have a SysML1.3::Block with some operations and when I edit the value of a tagged value and then select another operation within the block and than switch back to the edited operation my changes are gone. The strange thing is that when I change within an operation from the tagged values field to the behavior field and back the changes are saved succesfully.
The only solution to fix this problem is to restart EA, so even close and reopening the project won't work.
Does anyone have an idea what this could be?
Re: Tagged Values aren't saved
« Reply #1 on: March 24, 2017, 03:23:42 am »
have you tried a project consistency check (with fix errors)?
I used to have strange behavior in the features dialog (it wouldn't save any parameters) that was fixed after running said check.
