Author Topic: Compare a Diagram Name in vbs  (Read 4493 times)
Benny
« on: April 05, 2017, 10:57:36 pm »
I´m trying to compare two strings with each other, but it does not work : /
First of all the Code:
option explicit
!INC Local Scripts.EAConstants-VBScript
sub HidePrivateAttributes()
   ' Get the type of element selected in the Project Browser
   dim treeSelectedType
   treeSelectedType = Repository.GetTreeSelectedItemType()
   select case treeSelectedType
      case otDiagram
         ' Code for when a diagram is selected
         dim theDiagram as EA.Diagram
         set theDiagram = Repository.GetTreeSelectedObject()
         dim Ops
         dim Atts
         Atts = theDiagram.Name Like "XXX Attributes*"
         Ops = theDiagram.Name Like "XXX Operations*"
         If Atts = true then
         call hideAtt(theDiagram)
         Elseif Ops = true then
         call hideOps(theDiagram)
         Else
         End if
         ReloadDiagram(theDiagram.DiagramID)
      case else
         ' Error message
         Session.Prompt "This script does not support items of this type.", promptOK
   end select
end sub
Function hideAtt(diagram)
         diagram.ShowPrivate(false)
         diagram.Update()
End Function
Function hideOps(diagram)
         diagram.ShowPublic(false)
         diagram.Update()
End Function
But it seems that Sparx don´t like the "LIKE" Operator or I use it wrong.
Based on msdn homepage it is the correct syntax "result = string Like pattern  "
I tryed to use "Option Compare Binary/Text" but it send me an error "Statement expected"
I Know I'm lacking knowledge in VBS and it might be a simple VBS failure.
I search the web for tutorials but it all scripts it is no problem to use this operator.
Please maybe someone can explain this to me.
regards
Benny
« Last Edit: April 05, 2017, 11:25:40 pm by Benny »
Benny
Re: Compare a Diagram Name in vbs
« Reply #1 on: April 05, 2017, 11:04:03 pm »
ok one minute after I posted this i found, that "LIKE" is not available in VBS  :'(
I did it with instr()
         Atts=instr(1,theDiagram.Name,"XXX Attributes",0)
         Ops=instr(1,theDiagram.Name,"XXX Operations",0)
         If Atts = 1 then
         'call hideAtt(theDiagram)
         msgBox(Atts)
         Elseif Ops = 1 then
         msgBox(Ops)
         'call hideOps(theDiagram)
         Else
         End if
Yeah  ;D now I can move on.
« Last Edit: April 05, 2017, 11:31:21 pm by Benny »
