Author Topic: Addins  (Read 4234 times)
Maggie
Addins
« on: September 16, 2011, 09:43:31 pm »
Hi
How does one debug an addin using visual studio?
I cant run it as an application as it is a class library
Maggie
philchudley
Re: Addins
« Reply #1 on: September 16, 2011, 10:54:20 pm »
Hi Maggie
One option is to set EA.exe as the external program on the Debug tab for your add-in solution project.
When you build / debug your add-in, Visual Studio will launch EA and then you will be able to test your add-in.
The option is, after building, launch EA as usual and then you should be able to access your add-in
For more info, goto the Sparx Community site, where you will find excellent add-in tutorials and other resources by Geert Bellekens
Also the EA user guide is pretty good at getting started with add-ins
Don't forget to create the registry entries that EA needs since Visual Studio won't do that for you.
Best of luck
Cheers
Phil
Models are great!
Maggie
Re: Addins
« Reply #2 on: September 16, 2011, 11:02:04 pm »
Thanks!! :)
fwoolz
Re: Addins
« Reply #3 on: September 17, 2011, 07:47:58 am »
There are some things to look out for when debugging an EA add-in:
1. To run the add-in as it would normally run in production, you need to register the add-in for COM and create an EA add-in registry entry so EA can find the add-in.
2. You can't overwrite the registered add-in assembly with a newly-built assembly with EA running - EA will lock the current assembly and prevent overwriting it.
3. For the same reason, you can't use Visual Studio integration with EA while developing your add-in - the running instance of EA started by VS integration will do the same as in 2., above.
Fred W
Fred Woolsey
Interfleet Technology Inc.
