Author Topic: Scripting: remove assigned stereotype?  (Read 8372 times)
Hurra
    • Find me at LinkedIn!
« on: April 08, 2017, 12:29:03 am »
Hello!
I have made a simple JScript to add a stereotype to selected elements in the project browser. The problem is that it only adds stereotypes, not remove current stereotype. The applied stereotypes just keeps piling up. How do I remove applied stereotypes?
Thanks!
Robert.
!INC Local Scripts.EAConstants-JScript
!INC EAScriptLib.JScript-Dialog
* Project Browser Script main function
function OnProjectBrowserScript()
  // Show the script output window
Repository.EnsureOutputVisible( "Script" );
     // Get the type of element selected in the Project Browser
     var selElem as EA.Collection;
     var input=DLGInputBox( 'Enter new stereotype', 'Multi-select element update', '');
     selElem = Repository.GetTreeSelectedElements();
     for (i=0; i < selElem.Count; i++) {
var e as EA.Element;
e = selElem.GetAt(i);
e.Stereotype = input;
Session.Output('Element changed: '+e.Name+' changed stereotype to '+e.Stereotype);
e.Update();
e.Refresh();
Session.Output('All selected elements updated.');
OnProjectBrowserScript();
always learning!
Re: Scripting: remove assigned stereotype?
« Reply #1 on: April 08, 2017, 06:08:58 am »
Have you tried to just assign it a null-string?
You have to reload the branch with the element's package afterwards.
« Last Edit: April 08, 2017, 06:12:49 am by qwerty »
« Reply #2 on: April 08, 2017, 04:37:05 pm »
Also loose the call to Refresh() and try it with StereotypeEx iso Stereotype. For some reason that seems to work better.
« Reply #3 on: April 08, 2017, 05:05:17 pm »
It seems like Stereotype only works as long as there is only a single stereotype assigned. As Geert suggested StereotypeEx replaces multiple assignments. It also respects comma inside the passed stereotype and will split it into single tokens (what a crude interface). StereotypeEx had been introduced in a later EA release since older versions allowed only a single stereotype. Now this is completely broken. Well. EAUI.
Aaron B
« Reply #4 on: April 10, 2017, 11:33:23 am »
As Geert suggested, assign your value to StereotypeEx, not Stereotype.
Assigning values to Element.Stereotype intentionally does not overwrite existing stereotypes. If there is an existing stereotype on the element, then assigning a value to Stereotype will set that new value as the primary stereotype and the old value becomes a secondary stereotype.
Assigning to Element.StereotypeEx will overwrite any existing stereotypes on the element.
It's been that way for a very long time. (EA 6.5?)
Hurra
« Reply #5 on: April 11, 2017, 09:05:05 pm »
Thank you for all your answers!
I changed .stereotype to .stereotypeex which solved the issue!
always learning!
