Author Topic: Document Generation - BPMN model  (Read 6991 times)
tjlindsay
« on: April 12, 2017, 03:55:43 am »
Problem statement - I've produced a BPMN 2.0 collaboration model and now want to document it using the EA doc generator.  The structure of the package is as follows:
Level 1 - Package Name = BPMN Model
Level 1.1 - Business Process
Level 1.1.1 - Diagram
Level 1.1.2 - Pool
Level 1.1.3 - Pool
Level 1.1.3.1 - Activity
Level 1.1.3.2 - Start event
My report template is only documenting the elements at level 1.1.n, omitting everything below that level
Does anyone know how to recursively document all elements within the package please?
Help will be greatly appreciated.
TJ.
Re: Document Generation - BPMN model
« Reply #1 on: April 18, 2017, 11:44:12 am »
Your template probably doesn't have the child elements section enabled. (Make sure it's enabled but empty)
tjlindsay
« Reply #2 on: April 26, 2017, 06:16:59 pm »
Worked a treat - thanks Simon.
faisalshehab
« Reply #3 on: April 27, 2017, 01:34:54 am »
I have the same requirement but I just don't want the list of elements under the parent elements. All what I want is the diagrams under that parent element. So as soon as put an empty child element, I get everything; which I do not want.
I am not using the BPMN model, but I use "use cases" and generated activity and sequence diagrams that comes under the use case element.  I just want those diagrams only, because all the test case scenarios and the steps where already denerated as part of the element scenario section.
Faisal
