Author Topic: SysML, block element properties update time  (Read 3924 times)
hjkim
« on: April 19, 2017, 11:22:38 am »
In SysML,
I add 2 blocks in block definition diagram.
and connect 2 blocks with part association.
I expect properties field update so show that property on target block propertis compartment. But not showed.
After I select other tab and select BDD tab again. It show that property.
I use Win10, EA 13.
Helmut Ortmann
Re: SysML, block element properties update time
« Reply #1 on: April 19, 2017, 02:19:51 pm »
have you enabled References in the Diagram properties, Tab Element?
(e.g. F5 in Diagram, Element,..)
Kind regards,
Helmut
hjkim
« Reply #2 on: April 19, 2017, 03:21:03 pm »
Hi.
For example,
I add block1 and block2 and connect that blocks.
I expect block1's properties compartment on BDD view show "block2". but not display on BDD view.
(In block1's property window <alt+Enter>, Related>Links Relationships show block2 element connection aggregation)
So I click editor window's tab "Start Page" and click the bdd tab that I was working again. then block1 show property "block2".
For other example
I add block1, block2 and block3 and connect block1 and block2 with part association.
and connect block1 and block3, then block1's properties compartment on BDD view show block2 (but not block3)
« Last Edit: April 19, 2017, 03:39:35 pm by hjkim »
Helmut Ortmann
« Reply #3 on: April 19, 2017, 11:34:37 pm »
I think I have also observed the behavior you have described.
The best thing would be to make a bug report.
Kind regards,
Helmut
