Author Topic: State Machine State select Composite Diagram  (Read 4149 times)
PeterHeintz
« on: April 27, 2017, 08:14:42 pm »
When you add a state in a state machine you are able to assign a composite diagrams e.g. another state machine diagram (Select Composite Diagram) to it.
Later you are able to assign e.g. a State Machine as a classifier to that state (Instance Classifier…)  to use a substate machine.
When you drag a state machine to a state machine diagram by default “Drop as” is "Invocation (State)" what basically leads to the same thing as described above, however you are not able to assign a composite diagram any more (context menu item is missed).
Is that an intended feature, and if so why?
I belief it is a bug.
Best regards,
Peter Heintz
Re: State Machine State select Composite Diagram
« Reply #1 on: April 27, 2017, 09:16:55 pm »
It's EAUI (inconsistent as usual). Once you uncheck the "Composite" the menu also disappears. You should report that as bug.
PeterHeintz
« Reply #2 on: April 27, 2017, 09:56:46 pm »
Yes, I will do!
Just to be complete; it was build 1310 where I saw this.
Best regards,
Peter Heintz
« Reply #3 on: April 27, 2017, 10:24:54 pm »
It's the same in V12 (and probably earlier versions).
