Author Topic: Status for connectors  (Read 6046 times)
« on: May 02, 2017, 05:12:43 pm »
We're starting to miss being able to set a status on a connector.  For the moment, we are going to use a Tagged Value, but if it was a native function (and in particular, have a shapescript have access to getStatusColor()) that would be useful.
Reported,
Sunshine
  • Its the results that count
Re: Status for connectors
« Reply #1 on: May 02, 2017, 07:32:43 pm »
Sounds like a good idea. Theres been a couple of times I've needed that status on connectors too.
Happy to help
« Reply #2 on: May 02, 2017, 08:09:15 pm »
Since that would (likely) result in a database change, chances are higher for the last decade of this century to see the light for this one.
« Reply #3 on: May 03, 2017, 04:52:46 pm »
They could use one of those manifold fields.
Another way around the problem is to allow the GetStatusColor() query to have a parameter - which would be the value objected from the Tagged Value.
« Reply #4 on: May 04, 2017, 09:50:16 am »
It's been submitted as a Feature Request - no ID yet.
In the (apparently VERY) unlikely case that Sparx changes the DB table, can we also add Created and Last Modified Timepoints?
PS: Should I make this a separate Feature Request?
