Author Topic: Java API: java.lang.NoSuchMethodError for GetTreeSelectedElements  (Read 4750 times)
Pegasus
I guess I don' see teh forest for the trees...  But I need urgent suggestion
In my HybridScript I added support for baseline nad did static on most "constants" I defined inside my script
org.sparx.Package packageSel = m_repository.GetTreeSelectedPackage();
m_repository.GetProjectInterface().CreateBaseline(packageSel.GetPackageGUID(),startDate, baseLineNoteStr + startDate);
 and first time all works right, but suddenly I get following crash message...
java.lang.NoSuchMethodError: Unable to find GetTreeSelectedElements
at org.sparx.Repository.comGetTreeSelectedElements(Native Method)
        at org.sparx.Repository.GetTreeSelectedElements(Repository.java:788)
        at SparxSystems.RepositoryInterface.syncEaWithPtcData(RepositoryInterface.java:1665)
        at SparxSystems.RepositoryInterface.main(RepositoryInterface.java:1768)
[Loaded java.lang.Shutdown from shared objects file]
[Loaded java.lang.Shutdown$Lock from shared objects file]
I deleted the libs eaapi.jar and SSJavaCOM.dll inside my local "lib"-package, but nothing changes.
Re: Java API: java.lang.NoSuchMethodError for GetTreeSelectedElements
« Reply #1 on: May 08, 2017, 11:42:55 pm »
The GUID needs to be converted to XML format. See the appropriate GetProjectInterface operations.
