Author Topic: Glossary in HTML from model document  (Read 4548 times)
Uffe
« on: May 10, 2017, 01:58:42 am »
Hi all,
I'm trying to generate an HTML version of a model using a model document.
I've dragged some packages onto the model document element, hit Shift-F8 and the generation works fine.
Except that in the dialog I select to include the glossary, and no glossary node is generated.
When I do a non-model document HTML generation, just following the structure, the glossary is included if selected in the dialog, so it's there and there's nothing fishy with the generation template. It's only absent when I use the model document.
Is there a trick?
/Uffe
