Author Topic: Discarding connector and attribute details in generated document  (Read 4618 times)
mrblack12
I'm working on a template for generating documents on class diagrams, but I can't seem to find how to set the template up so that it shows only the class diagrams and classes. I tried using the Exclude filter option and then setting Exclude details for "Class" (Attribute is not shown in the list since it's not an element in its own right) and Exclude connector type to "All", but neither one does the trick.
Any suggestions on how to solve this?
Thanx
Rick
Re: Discarding connector and attribute details in generated document
« Reply #1 on: May 10, 2017, 01:17:41 pm »
Rick,
You simply have to untick the boxes for Element.atttribute and Element.Connector in the left tree.
(this tree is not always visible, check the buttons up top to make it appear if you don't see a tree of checkboxes on the left side of the template.)
mrblack12
« Reply #2 on: May 10, 2017, 06:35:27 pm »
Geert,
of course! Should have seen it myself so I was a bit to hasty in posting this question. Thanx again for your speedy reply!
Rick
