Author Topic: View Recordings from Recording Breakpoint in “Record & Analyze”  (Read 4960 times)
Lahzey
I am using Version 13
I also posted this question on Stack Overflow a few days ago (http://stackoverflow.com/q/43848720/5784265).
I am trying to record in my java application. To do this I imported the code (which generated a class diagram).
I then added a new Script in the Execution Analyzer. I left everything empty except the content of Debug -> Platform:
Debugger: Java
Default Directory: \\chca6021.eur.beluni.net\a469627$\Documents\workspace\HelloWorld (Root folder of my eclipse project)
Application Class: com.creditsuisse.main.Main (Class with the main function)
Command Line Arguments: (left it empty)
Java Virtual Machine Options: jre=C:\Program Files\Java\jdk1.8.0_112\jre\bin\server,-Djava.class.path=\\chca6021.eur.beluni.net\a469627$\Documents\workspace\HelloWorld\src;\\chca6021.eur.beluni.net\a469627$\Documents\workspace\HelloWorld\bin
I ticked "x64", "Show console" and "Show diagnostic messages" and chose the radio button "Run
Next, I opened the Main.java file (Select Class Diagram -> F12) and set the following break points:
public static void main(String[] args) {
      System.out.println("Starting");                       Start Recording Marker
      System.out.println(new HelloWorld("test"));
      System.out.println("Finished");                       End Recording Marker
When i now run it using the start button in the Record & Analyze Window, it will run successfully and print the following text is printed to the Debug Window:
... (Things like looking for...)
[25974654]      Loaded class successfully com/creditsuisse/main/Main
[25974655]      Failed to locate source file for class Lcom/creditsuisse/main/Main;
[25974655]      Class Loader is Lsun/misc/Launcher$AppClassLoader;
[25974667]      Starting
[25974743]      Looking for class com.creditsuisse.main.HelloWorld source in path chca6021.eur.beluni.net\a469627$\Documents\workspace\HelloWorld\src\com\creditsuisse\main
[25974753]      Looking for class com.creditsuisse.main.HelloWorld source in path chca6021.eur.beluni.net\a469627$\Documents\workspace\HelloWorld\bin\com\creditsuisse\main
[25974761]      Looking for class com.creditsuisse.main.HelloWorld source in path chca6021.eur.beluni.net\a469627$\Documents\workspace\HelloWorld\com\creditsuisse\main
[25974766]      End of recording
[25974767]      Hello World: test
[25974767]      Finished
[25982857]      Debug Session Ended
The Record & Analyze Window still says "There are no items to show in this view", how can I get the recorded history to appear there? (I need the history to generate a sequence diagram)
And what does the error "Failed to locate source file for class Lcom/creditsuisse/main/Main;" mean?
Thanks in advance
Edit: I also noticed that the application won't stop at normal breakpoints.
« Last Edit: May 11, 2017, 12:47:32 am by Lahzey »
Lahzey
Asked the Sparx Support:
The debugger is failing to resolve UNC paths for source files. So, the only workaround is to build it locally, or set up a symbolic link on the laptop to the UNC path and use that.
My source files are at: //chca6021.eur.beluni.net/a469627$/Documents/workspace/HelloWorld
Moving the project to a local directory (under C:/) solved the problem
