Author Topic: Associations & the Schema Composer  (Read 5160 times)
MatthiasVDE
« on: May 11, 2017, 11:58:08 pm »
I create e schema in EA13 and add some classes without to that schema, logically there are no associations visible in the schema composer.
But now, when I add the associations afterwards to my class diagram, the associations are still not visible in the schema composer. Next step, I remove the classes from my schema composer and add them again in the hope that the associations will be visible, unfortunately still no associations visible in the schema composer.
What next? I create a new schema and add my classes, now, the associations are visible.
Is it normal that you need to create a new schema to get some changes on your class diagram visible in the schema composer?
Re: Associations & the Schema Composer
« Reply #1 on: May 12, 2017, 01:37:53 am »
You need to close and re-open the schema composer for it to re-fresh the data from the model.
No need to create a new schema.
MatthiasVDE
« Reply #2 on: May 12, 2017, 03:17:29 am »
Thanks Geert!
