Author Topic: Setting Menu  (Read 6562 times)
ygautomo
Setting Menu
« on: May 14, 2017, 02:36:06 pm »
Hi All,
I want to ask about SETTING MENU in my EA 12 Interface.
I want to create a new user defined data type, in Help i should access Setting Menu, Next to Extensions Menu in Main Menu Bar.
But unfortunately i could find one.
I've check through VIEW/PERSPECTIVE and set all menu default to Complete, but still i could found SETTING MENU in main Menu Bar.
Please need help.
Ygautomo
Re: Setting Menu
« Reply #1 on: May 14, 2017, 05:45:58 pm »
Project/Setting/Database Datatypes if it's that what you are looking for. Else you should tell us what kind of data type you want to define.
ygautomo
Re: Setting Menu
« Reply #2 on: May 15, 2017, 02:24:22 am »
hi qwerty,
Thanks for the reply,
Actually i want to create User Data Type for MySQL such as data domain in Power Designer.
perhaps like city name or student id which is have max length 20 in varchar data type or specific enum data type.
ygautomo
Re: Setting Menu
« Reply #3 on: May 15, 2017, 02:36:15 am »
In that case the above is what you should look into. Did you find it?
ygautomo
Re: Setting Menu
« Reply #4 on: May 28, 2017, 01:11:37 pm »
Yes, i've find the menu.
I've tried to create User Defined Data Type "dCustomer_id" as VARCHAR(10);
But when i want to create with this domain name, found error when creates tables, because dCustomer_id not automatically convert to VARCHAR(10).
Is there any solution to implement domain or user defined data type in EA?
Thanks.
Ygautomo
« Last Edit: May 28, 2017, 02:27:22 pm by ygautomo »
Re: Setting Menu
« Reply #5 on: May 29, 2017, 12:44:55 pm »
http://www.dbmode.com/ may help with what you want
ygautomo
Re: Setting Menu
« Reply #6 on: June 09, 2017, 05:58:44 am »
Hi skiwi,
Thanks for the information.
I really appreciated.
