Author Topic: Question regarding uploading a new profile  (Read 5465 times)
tzafrir
« on: May 21, 2017, 06:35:23 am »
I have 2 questions regarding the procedure of loading a new profile:
1. Is the command Synchronize Stereotype (available in EA menus) is available somehow through the EA API.
2. If there is a specific tag of a Stereotype in a profile and in the model it has values.
If you rename the tag, and load a new MDG profile.
What I want to do is recognize the old tag, copy its value to the new tag and delete the old tag.
The question is does this recognition can be done?
thanks.
Sunshine
  • Its the results that count
Re: Question regarding uploading a new profile
« Reply #1 on: May 21, 2017, 08:09:10 am »
1. You can synch the stereotypes one at a time by right clicking in the tool box on the element and selecting synchronise stereotype.
2. Renamed tags will be added as new tags to existing stereotypes. The old tags will remain. You'll need to write your own script to copy the values and delete the old tags.
Happy to help
« Reply #2 on: May 21, 2017, 09:04:09 am »
1. Repository.SynchProfile
« Reply #3 on: May 21, 2017, 05:07:53 pm »
I have a script you can use to synchronize stereotypes:
https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/blob/master/Framework/Tools/UML%20Profile/Synchronize%20Steretoypes.vbs
You just need to fill in the stereotypes you need to be synchronized and the script does the rest.
Guillaume
    • www.umlchannel.com
« Reply #4 on: May 22, 2017, 11:19:07 pm »
I noticed that EA does not take into account renamed stereotypes so I had to define a script that lets the user enter the old & new stereotype name.
Once done, Geert's script can be run to update all stereotypes.
I didn't put a script to update tags as I left the users handle that, but it sounds sensible to write one.
Guillaume
Guillaume
