Author Topic: Link to Connector Feature - multiple connectors behaviour inappropriate  (Read 3526 times)
If you use the Link to Connector Feature functionality on a Note Element (say Link to Connector Note) and you have more than one connector attached to the Note, the displayed note will change (apparently arbitrarily).
However, it is NOT arbitrary, it appears that the Connector Note that will be displayed is that of the highest sequence number in the Set Attached Links dialog!  This is not appropriate!  There should be a checkbox against the Connector in the Set Attached Links dialog to indicate that a particular has been designated the one for the Note to be displayed.
Reported,
