Author Topic: Export class attributes in csv  (Read 6685 times)
MiniBlondie
« on: May 30, 2017, 11:23:54 pm »
Very basic question but I couldn't find the answer on the forum.
I would like to export some enumeration classes + attributes in csv format. I just can't find the option to select the attributes.
It seems such a basic feature that I can't believe it's not available. Is it? :-\
Thank you
Re: Export class attributes in csv
« Reply #1 on: May 31, 2017, 01:13:47 am »
You probably need to adapt the csv export script that comes along with the EAScriptingLib. Or you  use Geerts csv script (which would basically be the same effort).
« Reply #2 on: May 31, 2017, 02:06:45 pm »
Use an SQL search and then export the results to CSV.
See https://bellekens.com/2011/01/14/harvesting-the-power-of-eas-sql-searches/ for some examples.
