Author Topic: Add-in deployment in HKEY_LOCAL_MACHINE  (Read 3836 times)
Luis J. Lobo
  • IT Consultant
« on: September 29, 2011, 09:19:28 pm »
I've read in the v9.x "release note"s and "help file" that now it's supported to deploy an Add-In in the "HKEY_LOCAL_MACHINE" registry key to make it available for all users, but I can't make it work. I created the key "Software\Sparx Systems\EAAddins\xxx" key and logging with another user the Add-in isn't available.
Is there any way to make an add-in available for all users?
Re: Add-in deployment in HKEY_LOCAL_MACHINE
« Reply #1 on: September 29, 2011, 11:41:23 pm »
We have the simple policy: if you want to use EA you need to add the following .reg-file ...
« Reply #2 on: September 30, 2011, 05:50:04 pm »
Hmm, I moved the registry settings for my addins to the HK_LOCAL_MACHINE, but I never actually tested if this works for all users, I sort of assumed it would  :-/
« Last Edit: September 30, 2011, 05:51:39 pm by Geert.Bellekens »
