Author Topic: Visibility of attributes for Node  (Read 4139 times)
jankari
« on: June 08, 2017, 12:50:53 am »
I am trying to show attributes defined in a Node. I have tried the following:
  • In a Deployment diagram, use a Node element from the Deployment toolbox.
  • Open Node > Features & Properties > Attributes and add an attribute with all columns filled.
  • By default the attributes of all types are set to be visible in Features & Properties.
But, after doing the above, the attributes are not showing. I know I can get around this by adding Tags.
Thank you in advance for your time and reply.
Re: Visibility of attributes for Node
« Reply #1 on: June 08, 2017, 04:14:24 am »
You should be seeing attributes without any tricks. Maybe you have turned on some weird MDG? Try with an empty EAP, MDGs turned off.
Sunshine
  • Its the results that count
« Reply #2 on: June 08, 2017, 06:22:10 am »
Try checking the diagram properties on the element and ensure that attributes box is ticked. That seemed to work for me
Happy to help
