Author Topic: Extending Archimate 3  (Read 7116 times)
John Lynn
« on: June 10, 2017, 09:10:30 am »
Hello folks,
Is it possible to extend Archimate 3 to add new elements? Specifically I am exploring Capability-Based Planning which seems to add a new "Metric" element as part of Strategy. Ideally, I would like to create a new "Motivation Concept" element that has the same shape as an "Assessment" element but displays a different icon.
Thanks & Regards,
John
Sunshine
  • Its the results that count
Re: Extending Archimate 3
« Reply #1 on: June 10, 2017, 11:49:53 am »
Yes it is you can create an MDG that extends the archimate V3 stereotypes.
Happy to help
Guillaume
    • www.umlchannel.com
« Reply #2 on: June 12, 2017, 08:22:27 pm »
You can create Archimate custom stereotypes e.g. by extending the Archimate 3 capability + Class metaclass in your UML Profile.
The only known issue is that the Quicklinker can be broken (identified as a bug to be fixed by Sparx).
Guillaume
John Lynn
« Reply #3 on: June 21, 2017, 12:12:38 pm »
Thanks guys. I've been digging through the documentation and using a UML profile to create my new elements (with some success, they now display correctly with cunning little icons).
There are two things I still haven't been able to figure out that I was hoping to get advice on:
  • The UML Profile creates its own toolbox- I would like to make it a subsection of the Archimate3 toolbox (i.e. this is an extension of the Motivation diagram). Is this possible?
  • I would like to restrict which connectors each element can use based on the element it is being connected to (i.e. this new element can only "Realize" a requirement, it can't aggregate it). Is this possible?
Glassboy
« Reply #4 on: June 21, 2017, 12:23:34 pm »
You'll need to recreate the standard Archimate toolboxes in your MDG or potentially replace the Archimate3 MDG in your install directory.
Sunshine
« Reply #5 on: June 23, 2017, 07:59:29 am »
Kind of via the quick links. You need to set that up in the custom MDG you'll need to create to extend ArchiMate. See help for more details. AFAIK I don't think there is anyway to restrict the connectors being used via the toolbox selection.
Happy to help
